17 glc300 cel P0299 turbocharger underboost
Old Jun 25, 2024 | 05:56 AM
sn202020's Avatar
2017 & 2022 GLC 300 4Matic
My 240,000km glc300 got CEL of P0299, turbocharger underboost code, when I try faster than 120km/h.
Googling found it could be theTurbocharger wastegate actuator, and tested the actuator with a vacuum pump. Indeed, the vacuum was leak and only move 4mm actuator rod at 5psi.
​i ordered cheap Ali's A2740904380 (with rod length 19.6mm) for $33.
I received and installed new part, the vacuum moves 17mm rod at 15psi without leaks. E-ring removal and installation was hardest.
Old Jun 25, 2024 | 03:08 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Thanks for posting. Like the green tape to the cir-clip trick.
Old Jun 26, 2024 | 11:13 AM
mikapen's Avatar
Definitely!
Thanks @sn202020 for something that goes in my bag of tricks.
