DRL turned yellow
Old Apr 12, 2025 | 12:42 PM
ku0per's Avatar
DRL turned yellow
Hello,
My DRL turned yellow. Is it something that can be fixed or do I need to replace whole headlight?
Yellow DRL
Thank you!
Old Apr 12, 2025 | 02:03 PM
W205C43PFL's Avatar
Originally Posted by ku0per
Hello,
Yellow DRL
Thank you!
That is strange, I thought it was the housing, didn't know it was the actual LED, I wonder if it is a defective light module? Is it only this side?
Old Apr 12, 2025 | 02:05 PM
W205C43PFL's Avatar
Here is where the module is located, though that thread is a sedan, it might still be in the same location : https://mbworld.org/forums/c-class-w...light-mod.html
Old Apr 12, 2025 | 02:06 PM
W205C43PFL's Avatar
Light module to be specific, I mean the control light module, it is a chip.
Old Apr 12, 2025 | 03:18 PM
superswiss's Avatar
2019 C63CS
Unfortunately you'll have to replace the headlight. White LEDs turning yellow happens when the phosphor coating degrades and changes color. It's non-reversable. It happens naturally or due to too much heat exposure. UV radiation can also cause it. White LEDs naturally start to turn yellow over time due to natural degradation, but this is a major degradation that you have. Your headlight might be faulty and things got too hot causing the phosphor coating to rapidly degrade.
Old Apr 12, 2025 | 06:49 PM
W205C43PFL's Avatar
That is worse than I thought, thanks for chiming in though. Was hoping it was a simple solution for OP.
