Where does the Windshield washer fluid usually leak from?
Old Jun 26, 2025 | 11:11 PM
cyber3d's Avatar
GLC 300
Hi all,
My windshield washer fluid tank does not hold its water. By the end of the day there is not enough fluid left and I get the error message. Where does it usually leak from? Hoses? Where (at the tank? at the...)? Do the tanks ever crack? my car is a 2016. I am hoping it is something I can fix myself. TIA
Old Jun 27, 2025 | 03:10 AM
W205C43PFL's Avatar
Originally Posted by cyber3d
Hi all,
See if this helps:
https://mbworld.org/forums/glc-class...luid-leak.html
Old Jun 27, 2025 | 05:44 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
It’s unlikely a tank or a line cracked unless you used water in the system in winter. Not that it can’t happen but ice would be the normal cause. If the pump housing is cracked, you could be leaking from there.
does the fluid run out as soon as you fill the tank? If so, tank, pump and level sensor are in that space.
Old Jun 27, 2025 | 07:26 PM
cyber3d's Avatar
GLC 300
I'll fill it with water and watch where it comes out. Do I need to start the engine to test this?
Old Jun 29, 2025 | 09:54 PM
Baltistyle's Avatar
no. Try without to check the tank up to the pump and sensor grommets. If it doesn’t leak, turn on, operate the pump and see if it’s leaking from the pump or the connection to the lines or the line or the nozzles. Those would be your typical points.
