Diagnostic Assist P0011-77
Old Aug 3, 2025 | 08:48 PM
wirelessG's Avatar
e55
Hello
Glc 300 2wd 2018 108k miles
Car recently experienced some fuel pump issues and and while at first the car would crank and drive, it slowly got worse and now won't start at all. Fuel pump has been replaced. Recent code is p0011-77.
I am looking to sell the car ASAP so looking for a possible bandaid solution to dump to CarMax or if it's even worth to fix and just sell as is.
Any help appreciated.
Old Oct 4, 2025 | 11:07 AM
wirelessG's Avatar
e55
I finally got around to getting car scanned, is it worth fixing? A mechanic said no and it'll end up costing more than the car is worth. After replacing the fuel filter the car cranks and starts. HOwever, below are the current codes
P0011 - Camshaft Position timing
P052A - Cold Start A Camshaft Position Timing
P0087 - Fuel Rail System Pressure too low
P0016 - Crankshaft/Camshaft Position
P052E - Positive Crankcase Ventilation Regulator
P0341 - Camshaft Position Sensor
