Trans Service
Old Aug 13, 2025 | 02:22 PM
sgmstr's Avatar
2016 GLC300 4Matic
Trans Service
2019 GLC 300 RWD with 30K miles.
Got a quote from an independent mechanic $650 for trans fluid drain and fill with OE Parts including filter and gasket. Is this reasonably priced? In So Cal.
Old Aug 13, 2025 | 03:36 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I think it depends on the type of fluid, instruction set being followed, access to Xentry procedure, etc.
Old Aug 13, 2025 | 08:33 PM
W205C43PFL's Avatar
That's not terrible price wise being a 9G.
Old Aug 13, 2025 | 08:45 PM
Lagtime's Avatar
'17 IS350 F Sport '19 GLC300, '94 Supra
I paid $950 recently at the dealer for the trans service, if the independent is doing everything in the work instructions along with using all Mercedes parts/fluids that's good price.
Old Aug 13, 2025 | 09:10 PM
natesamg's Avatar
2020 E53 AMG Sedan
try Mercedes of Calabasas for a quote first if you're near them, their pricing is great for a dealer. definitely sounds reasonable though
Old Aug 15, 2025 | 02:27 PM
stath's Avatar
2018 GLC300 P01 selenite grey
I recently paid $1,000 at the Mercedes of Santa Monica for the transmission fluid service.
Somehow, I don't trust indies touching crucial parts of my GLC. It's my personal principle.
Old Aug 15, 2025 | 04:43 PM
sn202020's Avatar
2017 & 2022 GLC 300 4Matic
I did 8 liters replacement by myself under $200 with the compatible pan and fluid, years ago.
Old Aug 15, 2025 | 06:28 PM
natesamg's Avatar
2020 E53 AMG Sedan
this is aligned with other quotes i got from various LA dealers. will need to do this on my car next year
Old Aug 16, 2025 | 12:39 PM
KYGLC300's Avatar
2019 GLC300W4
I just did this service to my MY19 GLC300.
It was $300 for OEM parts and $200 for 10 liters of OEM fluid.
I drained the torque converter and pan, replaced the pad and ended up using around 8.5 liters of fluid. I did not do a flush.
Took about 3 hours to complete.
Dealer in the Cincinnati area were quoting $1500 for the service.
Old Aug 16, 2025 | 01:31 PM
W205C43PFL's Avatar
DIY? Good for you!
Old Aug 16, 2025 | 01:49 PM
natesamg's Avatar
2020 E53 AMG Sedan
don't you need to raise the whole car and cycle through the gears while checking the fill level? how did you accomplish that part
Old Aug 16, 2025 | 02:06 PM
KYGLC300's Avatar
2019 GLC300W4
No, that's not needed. Just need to measure the amount of fluid that you take out and fill 1/2 to 1 liter extras, then run the engine and allow the temperature of the trans fluid to reach 35 - 40C. Then you open the drain plug, set fill tube to positions 3 to allow the excess fluid to drain off. There is a tube attached to the drain plug opening that sticks up into the fluid that is at the correct fluid height. There are plenty of videos out there that describe the procedure better than the WIS.
I did shift thru the gears (P,R,N,D) while it was warming up (with foot on the pedal) just to cycle some of the valves, but it really isn't necessary.
Nowadays, the dealer does a flush so they don't have to drain the torque converter.
Old Aug 19, 2025 | 04:56 PM
kjb55's Avatar
I have done both a 2017 and 2018 (same process) using Xentry. It is a very specific instruction set that requires the parking brake to be set. Engine RPM increased to >2,800 RPM for >2 seconds. Valves are cycled in P and N only, temperature dependent to move to next steps. Once all steps are completed, then it's position 3 on the pan until a thin line to set level. Then position 1 and drain plug installed to complete the work.
