GLC 300 Rear Shock Absorber Replacement
Old Mar 11, 2026 | 08:12 PM
asiansensation7's Avatar
Hi all, does anyone have the service instructions on how to replace the rear shock absorbers on a 2019 GLC 300 (X253) w/o air suspension? It looks pretty straightforward but specifically I'm looking for the fastening torque values. Thanks in advance!
Old Mar 13, 2026 | 11:30 PM
Gazam's Avatar
Top nut to piston rod is 30 Nm. Bottom bolt to knuckle is 100 Nm plus 90 degrees. Make sure you support the knuckle when removing the bolt so the brake line doesn't stretch. Pretty straightforward job.
