2020 GLC 300 4MATIC — Auxiliary / Fog Light Add-On?
Has anyone installed auxiliary driving lights or fog lights on a 2020 GLC 300 4MATIC?
I’m considering adding additional forward lighting for better visibility (fog / dark rural roads), and I’m curious:
• What setup did you use (OEM-style, aftermarket, etc.)?
• Where did you mount them (lower grille, behind grille, bumper, etc.)?
• How did you wire them — factory integration or separate switch?
• Any photos or lessons learned?
Trying to keep it clean and close to factory-looking if possible. Thanks in advance.
OK, there's been about 121 views on this post but no replies LOL. So does that mean no one has added auxiliary fog lamps - Or - is there an issue with the post? Originally Posted by SuperTuscan
2020 GLC 300 4MATIC — Auxiliary / Fog Light Add-On?Has anyone installed auxiliary driving lights or fog lights on a 2020 GLC 300 4MATIC?
mikapen
close
- Join DateOct 2009
- LocationColorado
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive'21 AMG53 wDPP & ARC, 19 GLC300 - Former-03 C240,2 ML BlueTecs,20 GLE450 E-ABC,15 Cayenne D,17 Macan
Liked:2,187 Times in 1,647 Posts
Quote:
Your post is fine. Originally Posted by SuperTuscan
Apparently nobody has experience with auxiliary fog lights.
If you have intelligent lighting package, and you select Fog, the L.R. taillight gets much brighter, but more to your point, the headlights control their beams to reduce glare/reflection.
Thanks @mikapen , I'm surprised no one has added extra highway or off-road driving lamps, (e.g. Hella, CIBIE and the like) to these cars. It would seem the lower plastic section could be removed or artfully cut out to house a lamp there. Originally Posted by mikapen
Your post is fine.Apparently nobody has experience with auxiliary fog lights.
Even searching the internet provided a dirth of information. Thanks for the reply. mikapen
close
- Join DateOct 2009
- LocationColorado
It sounds more like an Overlander mod. Originally Posted by SuperTuscan
Maybe you can find an Overlander forum that addresses Aux lighting.
look this web site:Originally Posted by mikapen
It sounds more like an Overlander mod.Maybe you can find an Overlander forum that addresses Aux lighting.
https://offroadium.com/lifted-merced...oad-build.html
