GLC300 Coupe 2024 - HUD issues
Old Today | 12:32 AM
rajpotula's Avatar
Mercedes Benz GLC300 Coupe 2024
Hi All,
The car worked perfectly for two years (bought it in June 2024), but today afternoon, when I started the car, no HUD display. I went to the HUD menu through the buttons on the steering wheel, I could see the switch on and off (which is ON), height adjustment, brightness adjustment, everything is as normal, but I just can't see the HUD. I didn't get the error message "Heads Up Inoperative" like others reported.
I tried restarting the car multiple times, I soft reseted the MBUX, switched off the car and waited for an hour and checked again, no luck. Opened the fuse box on the passenger side, pressed the fuses slightly to see if anything is loose. One was loose, corrected it but still no HUD. Toggled the HUD off and on, but no change.
What could be the issue? I will call the dealer tomorrow and see what happens. Do let me know if there are any troubleshooting hacks Thank you, appreciate the support!
Old Today | 01:08 PM
rajpotula's Avatar
Originally Posted by rajpotula
Hi All,
Well, just like humans, sometimes cars just need a good night’s sleep too I guess 😊 The HUD started working perfectly again this morning!
