Squeaking noise from luggage cover
I got my GLC 2023 just last month. I upgraded from GLB so liking the difference. Initially the car felt very silent but I am noticing small rattles/squeaks creeping up already. Right now, my major issue is with the cargo cover.
If I remove the cargo cover, quite a lot of noises from the rear vanish. Any suggestions how to fix it or anyone else ran into it ?
1. I don't like my boot to be exposed for safety and it looks dirty with stuff kept sometimes
2. The car isn't cheap exactly and is barely over a month old, so I should not need to resort to such workarounds. If there is an issue with the luggage cover, the dealership needs to fix it.
I highly doubt your dealer will be sympathetic about the situation. They'll probably tell you "use it or lose it"!
I did wonder if it was actually the side panels that were creaking but I then, 17th November, another driver had one delivered so I swapped the covers and the new one was fine again so clearly the cover was the issue. The new one was fine unitil 11 decrmber when i got the odd creak/squeak and now it is gerring worse each day.
There clearly is a problem with these and everyone needs to be complaining to the dealers as this is not what you expect and should have to put up with on a 'premium brand' car.
