GLC Class (X254) Produced 2023+
Suspect Wiring harness / unable to …
Old Nov 9, 2024 | 08:36 PM
claudiag1971's Avatar
today after a giggly ride on a rutted out dirt road, my engine light came on in my GLC 300 SUV and when I went to AutoZone to get the exact code readings, this is what came up :
Unable to engage in reverse code
communication with electronic ignition lock has malfunction code.
Communication with steering column module has a malfunction code.
I suspect it is the wiring harness because it was just changed out three months ago.
it seems to drive just fine unless I try to back out of a parking space in reverse then it just wants to jump back into neutral. My question is….
​​​​​​….. does anyone know where the connection is on the wiring harness to these issues? Does it go directly to a computer box? Maybe something jiggled loose and it needs to just be re-attached.
FYI, my mechanics shop just burned down so I am suspecting the warranty is not good since I cannot get in touch with him and all his equipment is unfortunately ruined. Anyone have any ideas?
Here are the codes
Here are the codes
Old Nov 10, 2024 | 10:47 AM
trigital's Avatar
W213 All-terrain
GLC W254? Those benefit from warranty at any MB dealer.
There is no wirings connection regarding engaging the Reverse. Normally - but for high mileage cars - is the pressure sensor inside the TCU.
