Zac composites intake
Old Nov 23, 2019 | 10:20 PM
Phat63s's Avatar
GLE63s
Just finished installing zac intakes on my glc63s map sensors were abit of a pain otherwise not to bad. Engine is stock at the moment will be doing secondary cat delete ECU and tcu tune shortly. Still have to glue on build plate
Old Nov 23, 2019 | 11:35 PM
KingMonkeyJr's Avatar
GLC 63 AMG, Trackhawk, X3M
Where are you located and who is doing the tcu?
Old Nov 24, 2019 | 12:36 AM
Phat63s's Avatar
GLE63s
Located in sydney Australia allen from international autohaus.
Old Nov 24, 2019 | 03:04 PM
CPD SLK's Avatar
2009 C63 AMG
Still need to install mine. Any tips or tricks for the MAF sensors or any other parts of the install?
Also. did you notice any louder turbo spool noises or improved response/performance characteristics?
Old Nov 24, 2019 | 03:59 PM
Phat63s's Avatar
GLE63s
Yeh u can hear turbos spool and wastgates working now actually sounds like a turbo engine. Throttle seems more responsive also. U can tell its breathing alot better. Maf sensors are glue into rubber boot I had to slice it to get off got sick of fighting it. If you cant pull airflow sensor out of manifold disconnect wiring harness then once u remove old intake you can twist and push out from the inside. There is a clearance issues on left side when looking at engine I had to cut a screw down to clear filter. Lube up the adapter where maf sensor go it's pretty tight
Old Nov 24, 2019 | 04:13 PM
CPD SLK's Avatar
2009 C63 AMG
Thanks for the info! Much appreciated.
What did u use for said lubing lol? Like some teflon spray or??
Old Nov 24, 2019 | 06:46 PM
Phat63s's Avatar
GLE63s
Just used wd40 and wiped clean so it doesnt mess with sensors. Didnt take Watergate hose all the way off yet as you cant get pliers in without taking off a few shrouds couldn't be bothered.
