AGRESSIVE FITMENT!!
like it to look more aggressive like the GLC63 with the same size tires.
i know they won't look exactly the same cuz of the wheel width of the wheel and all, but it will definitely look better. Plus I don't like the ride of the run flats. i think they should fit ok without any issues. any advice or tips are welcome. thanks ....
(run flats are available if interested, like new)
Stock size
fronts=255-40-21
rears=285-35-21
New size
fronts=265-40-21
rears=295-35-21
interested in this as well but not sure if they will fit.
http://www.ebay.com/itm/21-inch-GLC6...wAAOSwKoRZY5W2
on the rear, I am 10.5 wheels wrapped with 315" tires.
if you choose your tire width first, your next challenge is deciding on the matching sidewall profile that would match your tire height.
In my case, I went down to 28.7" tall tires so I am now o.6" shorter than stock tires. To achieve that my tires are 275/40 and 315/35.
Every single choice for width and height was my decision, including my wheel offset which is 15 front, 25 rear. I also have 22" wheels which are same height as stock at 29.3". I kept my front tires at 265 wide for that set in order to match the stock height with 295/35/22. rear is 315 wide there also.
this is my 22" with 265/35 in front over 9" wheel with +20 offset
this is 20" x 9" wide wheels in +15 offset. 275/40 tires wrapping it.
315 from the rear
A bunch of tire specs i gathered.
rear
front
