COST SAVINGS - INCREASE TIRE LIFE
I need whatever rear and front adjustable arms that will allow me to get to 0 degree camber on both axles to keep the tires flat on the ground.
I own a 2019 AMG GLC63 4MATIC (non-S model)
Please help me figure out what to buy, thanks much
Larry.
Larry.
Front upper arms ( up to 2.5 degrees + - Camber change).
Not welded / Fabricated but same as OEM high strength forged alloy.
#503316-2J $380
Front upper arm inner bushings (fit on vehicle - bush extraction tool included).
Up to 1.5 degrees + - Camber change !
Also the security - retaining the OEM high strength arms.
REAR
#502226-4M $595
Upper adjustable Camber arms (also extra Toe adjustment to compensate for Camber change).
