Fuse map for 2020 GLC43
Subscribe
Apr 20, 2020 | 07:43 PM
Anyone got a update fuse map for 2020 GLC? I googled one for 2017-2019 GLC but not sure if it applies for 2020.
Would love to get my radar detector reconnected.
Reply 0
Mar 17, 2021 | 09:34 PM
Old dead string, but I will second this request. Can't seem to find this.
Reply 0
Mar 18, 2021 | 04:46 PM
Did you check under the trunk cover? I have one located in there close to the fuse box.
Reply 0
Mar 18, 2021 | 05:00 PM
Thanks! I sure did! And I found it early this morning. This project has been like a treasure hunt. It seems the 2020 dash fuse panel has indeed been revised; there are fewer fuses...and there is no 216 or 217. So, today I changed course. I pulled down the overhead console and located the brown and green wires that power the mirror. I think I am going to be tapping into those connections.
Reply 0
Mar 18, 2021 | 05:03 PM
Quote: Thanks! I sure did! And I found it early this morning. This project has been like a treasure hunt. It seems the 2020 dash fuse panel has indeed been revised; there are fewer fuses...and there is no 216 or 217. So, today I changed course. I pulled down the overhead console and located the brown and green wires that power the mirror. I think I am going to be tapping into those connections.
I had tapped into those (don't remember the color) on a W204 and it worked well. Currently using the wire connected to the #216 fuse on my X253 and it also works well.
Good luck!
Reply 0
Aug 25, 2021 | 04:32 PM
Quote: I had tapped into those (don't remember the color) on a W204 and it worked well. Currently using the wire connected to the #216 fuse on my X253 and it also works well.
Good luck!
So eventually I went back to see what fuse I had tapped into, and that is #216. The Fuse Map document says it is "Glove compartment light".
Reply 1
Subscribe
Currently Active Users (1)
