Eurocharged CPC/TCU/ECU tuned 2020 GLC63 results
Old Nov 17, 2023 | 12:45 PM
GLC63v8's Avatar
GLC63 2019
OP, I think my car is having exact same issue as yours did before the ECU tune. Did you figure out what was wrong? Did EC tune completely eradicate any initial sluggishness? Thank you so much for sharing your experience!
Old Dec 3, 2024 | 04:29 AM
Simon89's Avatar
2016 GLC43
@brad65ford have you lowered via the OBD port or using lowering links?
Old Dec 3, 2024 | 07:02 AM
brad65ford's Avatar
2020GLC63
This time around I did lowering links, may switch up to a controller / module eventually for now the links are fine, just takes time to get them excellently how ones likes .
Old Dec 3, 2024 | 07:06 AM
Simon89's Avatar
2016 GLC43
Thanks. I assume they're easy enough to adjust once on the car?
Old Dec 3, 2024 | 07:08 AM
brad65ford's Avatar
2020GLC63
Kind of more of a pain in the butt some times depending how easy they are to get on and off. I have a lift so its not that bad, there is not directions on line that stated which direction to go so at first it was trail and error. Fronts links need to be longer to go lower and rear needs to be shorter to go lower, just a heads up ;-)
Old Dec 3, 2024 | 07:16 AM
Simon89's Avatar
2016 GLC43
Awesome - thanks! A lot of places seem to charge quite a lot for what looks to be an easily sourced part
Old Jan 24, 2025 | 08:53 AM
  #32
Vinithing's Avatar
2018 XC90
Is the 2020 GLC63 stage 1 Eurocharged ECU tune done via OBD2 port?
