2020 AMG GLC 63 City Driving
Old Mar 29, 2021 | 01:31 PM
gserp4sox's Avatar
2016 Genesis G80 5.0 - 2022 AMG GLC 63 S Coupe on order
Not quite. The issue occurred under light to medium braking. The harder, more spirited you slow down the smoother the downshifts actually get. If you slow down spirited it even skips gears like going from 7 straight to 5, and then straight to 3 or maybe even 2. In fact the shift strategy is amazing when driving spirited. This is the first transmission I can drive in automatic mode w/o getting frustrated when I'm expecting a sudden response out of the drivetrain, like suddenly need to accelerate. Also even in Comfort mode it seems to always be in the right gear and ready to accelerate again, as opposed to other automatics that hang out in a high gear and then have to scramble to downshift when you are ready to accelerate again and do it a bit more spirited like out of a turn. It's downshifting very proactively. This does mean that it is less comfortable, though, because there is more engine braking in lower gears. Many other transmission stay in high gears to almost glide when you take the foot off the accelerator, whereas this one quickly starts downshifting the moment you take the foot of the throttle pedal.
The roughness happened when coming to a steady slow stop like a granny stop. For the most part the downshifts are smooth, but that final downshift from 3 to 2 at those slow speeds caused the bucking. Basically, the brief interruption of engine braking during the shift and then the stronger engine braking of the 2nd gear, causes the bucking. Pretty much what happens in a manual transmission if you downshift at very low speeds and let the clutch out too quickly instead of letting it slip to ease in the engine braking. I found the stock brakes in my C63S (the GLC S I believe has different brakes) were not as linear as I wished and somewhat difficult to finely modulate at low speeds. The way I've learned to work around it is to let off the brakes while it downshifts from 3 to 2 and then get back on the brakes. That way the downshift is super smooth. I only have to do that if I creep to a stop essentially. It still occurs a little bit with the new brakes and I apply the same strategy, but the new brakes are more linear and easier to modulate.
Understood. Thank you for spending the time with your detailed replies. The more I go round and round trying to convince myself my wife will find this vehicle acceptable for her purposes, and won't be bugging the bejesus out of me, the more it's becoming apparent there's no way to be sure without just biting the bullet and rolling with the outcome. Currently thinking I'll do the 63s with the ceramic brake package and cross my fingers Thanks again.
Old Mar 30, 2021 | 02:37 PM
SafeDrive's Avatar
2020 Mercedes-Benz GLC 63
I had the same jerky transmission issues (even in comfort mode) and sent my 63 to dealer twice for check but there is nothing they can do to fix it. After putting 7000 miles on it, the issue is mysteriously gone. City driving is very smooth. So my guess is the transmission needs at least 5k miles to truly break in.
Old Mar 30, 2021 | 08:02 PM
gserp4sox's Avatar
Your not alone. I've seen a few people say the same thing as I've read through this and other forums. I can't say anyone really knows why. Some have said there was a tranny software update. Others think it's adaptive tranny learning. While others, like yourself , think it's due to a break in period. I wish someone in the 'know' would give us all the actual reason, because it's not magic!
Old Mar 31, 2021 | 08:57 AM
kennys2003's Avatar
2003 Cobra / 2018 GLC300 / 2020 GLC63 SUV
are we sure that it's not the driver getting used to the way the transmission works instead of it being mysteriously fixed by break-in ?
Old Mar 31, 2021 | 06:51 PM
superswiss's Avatar
2019 C63CS
That's absolutely part of it. We all develop our muscle memory and learn how the car acts in different situations and adapt to it. But the transmission is also learning and adapting to one's driving style, and the clutch packs are wearing in over time. It's not magic, but we all have different driving styles and drive in different environments, so no two adaptations are the same. All my cars took several 1000 miles before they started to feel right. The Human Machine Interface has to develop over time before both sides get along. All my performance cars didn't start to feel right until about 8000 miles and provided they were maintained properly, they got better over time as the manufacturers came out with software updates and all the parts in the car wore in properly, adapted and things loosened up, and I upgraded some parts such as tires and brakes. At the same time my confidence in the machines increased over time and they became more enjoyable and more fun as I learned the limits and behaviors.
Old Apr 21, 2021 | 12:55 PM
JonnyO's Avatar
2018 GLC63
Either my wife and I have gotten used to our GLC63 or it has gotten used to us. Perhaps it's a little bit of both. The gas pedal can sometimes be a bit touchy for a smooth low-speed launch but not overwhelmingly so- I fully agree with the comments above about some drivers simply not being used to it. The converse of this is that when you intend to put your foot down the vehicle does exactly what you want it to do, with zero delay. To me, that's the way it's supposed to be. The ride is firm, especially on the rutted moon surface that the City of Chicago calls 'a street', but not punishingly so. I suspect some have a preconceived notion of what the ride should feel like before they get in, thinking that an MB star on the front automatically means it should always ride like an S-class.
Old Jul 14, 2021 | 07:59 PM
  #32
Toughen's Avatar
C63s
The tranny is fine, but I worry about all kinds of noise inside the car, when driving with radio off and windows closed. this is my experience after 2years.
Old Jul 15, 2021 | 02:45 PM
  #33
ParadigmDawg's Avatar
AMG GLC 63s Coupe
$30,000 car with a $70,000 motor... just turn the radio back up....
Old Aug 9, 2021 | 03:39 PM
  #34
DuaneC63's Avatar
AMG GLC63. Audi R8
just leave it in Comfort mode for daily driving an hit the defeat button for the stop/go feature. I also leave the exhaust partial bypass on.
Old Oct 22, 2021 | 01:47 AM
  #35
KMKA's Avatar
AMG-GLC63
I’m new to this site/forum… so guessing by now you’ve already committed to filling your garage with something or a bit of both… The way I view mine, is she just wants to bolt outta the gate and run free. She LOVES the open roads, she’s a blast on windy roads at high speeds and low gears. You just gotta keep her in line with gears, as she’ll want to go to 5th doing 25mph if you let her. But she gets to know you, and your style. Not intuitive, but as any relationship could be when converting it to be likened to an animal and trainer. Mine only ‘bucks’ when she’s ready to bleed… other than that it is just her ‘moods’ some days and if she can have a lick of road and open up to over 100mph, she is much happier and settles down for running errands and the stop and go of those pesky lights.
I AM the wife. I do NOT let my husband drive my car EVER. He would crash and burn hard. As he just isn’t a car-guy or even a good driver for that matter. After his most recent run in with a solitary object, he’s starting to understand why I don’t and won’t let him drive my sassy girl. She’d buck and launch him… like the 469 horses she is.
