2019 AMG GLC 63 Brakes
Old Oct 16, 2021 | 02:30 PM
superswiss's Avatar
2019 C63CS
Originally Posted by Serge81
GLC has 360mm rotor, C has 390mm, they cant fit without custom caliper bracket.
There's a 360 mm version of the rotor for the non-S models. C63 has 360 mm, C63S has 390 mm rotors.
https://www.fcpeuro.com/products/bra...mbo-2194210212
Old Oct 16, 2021 | 07:00 PM
Serge81's Avatar
GLK350 2013, GLC63S AMG
Yeah i know but has any1 tried to compare stock and that brembo floating 360mm ones ?
Old Jan 18, 2022 | 09:40 AM
OPM GT3's Avatar
Porsche GT3
Front Brake Discs 390mm
Porsche Caliper Bolts
GiroDisc 390mm x 36mm P/N A1-123
Old Jan 6, 2023 | 01:12 AM
GLCya63's Avatar
2020 AMG GLC 63
GLC63 Brembo Rotors F&R...Good Price
After over 80K miles, it was time to replace the rotors. I really wanted to go with Girodisc front and rear since they cost as much as OEM replacements, doing the work myself. Since I had other stuff to purchase, I decided to try to find a cheaper but still OEM or Brembo options. I think most know about the 2-piece floating 390mm Brembos, but after searching, I never found a good alternative for the rears. There are other brands like Zimmerman that are pretty cheap but really wanted to match the fronts. I finally found a 1-piece Brembo that is exactly the same dimensions as the OEM MB, but only $183 ea. instead of $600 ea. Total cost for front and rear were less than $1300, see pic. I went with Power stop Z26 front and Z23 rears. Both sets cost less than $100 and come with all the pins and clips, the rears even came with new dust boots. After several hundred miles, I'm super happy with this combo. Not as grabby as OEM pads, but pretty damn close with no dust.
Total cost for rotors front and rear with PN#
Rear rotors
Installed front 2-piece
Old vs new. OEM is 31lbs., 2 PC are 29.5lbs
Old Apr 8, 2023 | 05:10 PM
berti_00's Avatar
2016 Cls63s AMG
