Was going to do first oil change, ...
Old Apr 17, 2022 | 07:32 PM
NIXDSG's Avatar
GLC 63
and as I was looking at the steel plate that needs to be removed, I noticed oil around the rear right hole. Also oil on the soft panel behind it, a 6" wide oil streak going back. FYI, 2021 63.
I remove the steel l panel and I see oil on the transmission? Wiped it off, will keep an eye on it.
Removing the oil plug is an event of oil power flowing out! Be ready, it's impressive.
removing the oil filter is a mess, too.
Easy access, yes. Messiest I've ever changed, yes.
Old Apr 20, 2022 | 01:11 AM
PartyVan's Avatar
2013 C63 Coupe P31 2021 GLC63s Coupe
My glc63s had an oil leak from day 1, it was a slow drip coming out from of the the bolt holding the plastic oil pan it will not leak when engine is off only when it's running so there was no oil stain on the garage floor. I fixed it myself by sealing the oil pan with RTV.
