Sherlock OBD protector
Has anybody used a Sherlock OBD protector to prevent the car from being stolen?
I came across this device made in Germany and sold in Canada by Sherlock company.
My concern is that it is bolted right into the OBD plastic port with 2 steel keyed bolts.
Will the port crack when installing the protector and make the diagnostic port unusable?
The exorbitant price of $200 CDN is another problem.
Your comments will be much appreciated
http://www.sherlock.ca/en/new-obd-protector/
Can anybody recommend OBD cover/protector that worked well for them?
Here I found a video with a clear explanation of how cars are being stolen using your car keyfob.
Another OBD protector but it is not presently available:
Will be Glc43 in few weeks
Hi.
I wouldn't go for this ugly and physically dommageable hardware.
I use this obd blocker on my glc43.
https://www.carnlink.com/obd-blocker
It is in french but Google can translate it.
You can also buy simple parts for 10$ and invert the obd cables yourself.
What you should know is where are the + and - and don t invert them as if your workshop tries to read via obd without your dongle it will burn the ecu.
