2020 GLC 43 weird sound near engine
Old Aug 19, 2023 | 11:12 PM
Jzxc's Avatar
20 GLC 43
anyone know what the problem is?
File Type: avi
Old Sep 1, 2023 | 11:24 AM
TheFuzz's Avatar
GLC43
boost transducer in front of the small coolant expansion tank under the intake duct
Old Sep 1, 2023 | 07:15 PM
W205C43PFL's Avatar
Yup that is exactly it, looks and sounds like a fairly common issue, there were multiple threads on the W205 C 43 sub-forum as well on this issue.
Thankfully this part is easy to replace and not expensive as well.
Old Sep 2, 2023 | 01:21 AM
Jzxc's Avatar
20 GLC 43
thanks guys
i found another sound coming from the two little speakers near the sunroof button, is this a common issue too? i took a video with the car engine off
https://www.youtube.com/shorts/OWBbmXcIG34
Old Sep 2, 2023 | 12:56 PM
W205C43PFL's Avatar
Originally Posted by Jzxc
thanks guys
Hmmm, sounds like a small motor but I can't really tell what am I supposed to hear because I might be hearing something other than what you are hearing, I do hear someone laughing in the background. Do you mind pointing out the exact timestamp of when the sound occurs and the loudest.
Old Sep 5, 2023 | 12:15 AM
Jzxc's Avatar
20 GLC 43
i think it is the small motor-like sound your hearing which starts at around 6 secs when i moved the camera near it
Old Sep 6, 2023 | 07:55 PM
W205C43PFL's Avatar
Hmmm, yes in that case I couldn't think of what motor is inside there, sunroof? but that isn't even open, the camera of the DISTRONIC also doesn't move (if you have DISTRONIC equipped) but even if it is a camera lens moving, it will make a click sound and it stops after it is done. Hopefully someone else can chime in.
