305 or 315 tires
Old Apr 10, 2024 | 02:23 PM
tedboss1's Avatar
GLC63 AMG S Coupe
305 or 315 tires
I,m trying to decide on what wider tires I should use on my factory 10-inch wheels.
If any of you tried this combination;
305/30R21 or
315/30R21.
I'm looking at Michelis Pilot 4S.
The front will remain stock 265/40R21.
I would like to avoid any problems with the tires rubbing or needing a spacer.
My car is a stock 2019 GLC63S
Thanks for your help.
Old Apr 10, 2024 | 06:18 PM
streborx's Avatar
Top Answer: 1
G550
0.4" difference -- from how far away can you tell?
Old Apr 15, 2024 | 08:34 PM
tedboss1's Avatar
GLC63 AMG S Coupe
Can anyone share their experience with either 305 or 315 rear tires install?
Yoy help will be appreciated.
Old Apr 16, 2024 | 01:08 PM
Bank$'s Avatar
GLC 63
What's up Tedboss I got yelled at by my tuner for going too much outside the % variation for the AWD system. They are very picky and car wear out the transfer case if your wheel diameter is too far off from the stock setup. Can you run a 305/30 or 315/30 and it work? Yes many have. But, longer term it could cause issues just FYI.
I'd recommend going with a 305/35/21 - it's less than a 1% difference. Check out the calculator here for changes in wheel diameter: https://www.calculator.net/tire-size-calculator.html
Our stock tire rear tire size sucks no super sticky tires (DR, autox) available in 20 or 21.
Old Apr 16, 2024 | 07:47 PM
tedboss1's Avatar
GLC63 AMG S Coupe
Bank$.
I like your recommendation for going with 305/35/21 tire.
One problem. I was not able to find this size in Pilot Sport 4S tire to match the stock front.
Is 4S even made in this size?
Old May 8, 2024 | 01:42 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
The factory tires on the front is stretched and the tire on the rear is already bulgy at 295. You need wider wheels to run a 305 or it won't look good imo.
R.K.
