PERFORMANCE AMG - YET NO FRONT OR REAR CAMBER ADJUSTMENT
Old Feb 21, 2025 | 01:59 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Yes AMG conjures up “Performance”. But reality is still a “mass produced” vehicle with
speed of production - cost / efficiency still the underlying criteria !
Hence still soft rubber suspension bushings and no Front “Camber” and “Caster” or
Rear Camber adjustment - only basic Front and Rear ‘TOE’ - directional adjustment
But essential to be able to dial in extra neg. Camber for performance handling or Track days.
Dramatically reducing understeer - deeper into the corners with increased traction and braking response.
Yet just as essential for day to day commuting - having the advantage of ongoing individual
adjustment to cater for varying road or load conditions. Allowing adjustment of tire contact
angles to spread load more evenly therefore resolving costly, premature excess edge tire wear.
K-MAC kits are also designed to require no special tools or
time consuming need to remove control arms to install !
Plus Unique Patented Design also allows ultimate adjustment -
Easily accessible, single wrench - direct on alignment rack UNDER LOAD !
Both Front and Rear adjuster kits - bushings are also “uprated” for
Performance handling and significantly improving Brake and Steering response !
DHL Express Air $40 one kit ($20 each extra)
sales@k-mac.com ….web: www.k-mac.com ….1888 847 9099 (Sales Tech 24/7)
ALL C253/X GLC incl. C43, 63/S, AMG SUV & Coupe.
FRONT SUSPENSION
4MATIC / AMG
CAMBER (ONLY) #503416-1i $345
(Both Sides)
(LESS COST THEN 1 QUALITY TIRE).
CAMBER & CASTER #503416M $595 (Both Sides)
NON 4MATIC
CAMBER (ONLY) #502816-1i $345
(Both Sides)
CAMBER & CASTER #502816M $595 (Both Sides)
All above kits provide up to 2 extra degrees Pos. or Neg. (more than enough to resolve majority tire wear issues).
Caster bushes are Mono ball / Self aligning. Replacing the OEM soft rubber bushings.
Still allow arms to travel through their required suspension arcs but significantly improving Brake and Steering Response
REAR SUSPENSION:
AMG
CAMBER (& EXTRA TOE) #502326-1K $480
(Both Sides)
AIRMATIC
CAMBER (& EXTRA TOE) #502326K $480
(Both Sides)
COIL SUSP.
CAMBER (& EXTRA TOE) #502226K $480
(Both Sides)
*All above Rear kits (same as front) - fit without need for arm removal or special tools. Easy access single wrench adjustment.
UPRATED REAR BUSHINGS FOR THE 6 MULTI LINK REAR ARMS
#502628K $480
Tauter response - Less Rear end Flex, Loss of Traction. Especially when applying power to lane change / overtake.
UPRATED REAR TOE ARMS - Prevent flex / Toe change.
#502326-3J $380 (Both Sides)
(use in conjunction with above Rear Camber & Toe kit).
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings (and Costs) Since 1964 !
