GLC43 Coupe [C253.364] Suspension Squeak & Lower Control Arm Part Numbers
Currently experiencing this front suspension squeak over bumps, (expected at 50,000 kms from what ive read) and considering replacement of either the lower control arms or arm bushings.
- Not surprised the change out of the whole arm is marketed as the solution rather than pressing out and replacing the bushings themselves.
Anyway,
Sourcing these lower control arms ive seen them referred to as 'Spring links'.
All well and good but now the actual part number is confusing... ive seen multiple IDs referring to whats assumed is the same part but some its been noted that it will not fit airmatic suspension which I do have.
Alot of it seems contradictory.
Im after the the rear lower link which is identical LH and RH, but cant see if it's got a part number from underneath.
Looking it up im getting the below results..
- 2053304507/2053306710 - (fits models without air suspension) Amazon.ae -ApplianPar; Bomunik
- 2053305801 - Does not fit (rmeuropean.com)
- 2053306710 - Does not fit (rmeuropean.com)
- 2053308403 or 2053308403(64) - Does fit (ecstuning.com) does not fit (rmeuropean.com)
Hoping for some confirmation as they vary wildly in prices and shipping.
Cheers.
