Wheels obstruct access to valve stems
Old Jan 16, 2026 | 04:37 AM
Jbnonc's Avatar
2025 AMG GLC43 Coupe
New 2025 AMG GLC 43 owner with 20” 10-spoke wheels. Tried to add air to the tires but access to the valve stems is severely restricted by the design of the wheels making removal of the stem cap extremely difficult.
Wondering if the trim surrounding the valve stem is meant to be removed in order to gain proper access.
Assume other owners have experienced same?
Old Jan 16, 2026 | 08:52 AM
streborx's Avatar
Top Answer: 1
G550
You posted no photo to illustrate your problem, but there are many air inflator chuck designs. One that has an extension and right angle end might work for you.
Old Jan 16, 2026 | 12:49 PM
Jbnonc's Avatar
Thanks- there’s not even enough clearance around the valve stem to get my fingers in there to unscrew the cap.
I’m having to use needle-nose pliers to reach in and unscrew the cap- this cannot be right.
Old Jan 16, 2026 | 01:43 PM
Mort's Avatar
I used a small 1/4 “ socket with a 4 “ extension that just fit over the cap without compressing it too much to remove the valve caps. Sorry I don’t remember the size of the socket. They are hard to get your fingers on to get them started. Frustrating for sure.
Old Jan 16, 2026 | 02:58 PM
Jbnonc's Avatar
Thanks so much bro. The day after I drive the car home I get an alert the tire pressures are off- understandable given sharp drop in temperature overnight. Still, the last problem I ever expected to encounter is an inability to access the valve stems. Defies reason why wheels would be designed this way. Thanks again!
Old Jan 16, 2026 | 05:40 PM
streborx's Avatar
Top Answer: 1
G550
Maybe you could install valve extenders that dually owners use.
Amazon Amazon
Old Jan 16, 2026 | 06:23 PM
Jbnonc's Avatar
https://www.amazon.com/Qulkws-Extend...8603142&sr=8-7
BRILLIANT!
Thanks for the tip!
