Tire Rotation
Old Jun 9, 2019 | 12:20 AM
bkushner's Avatar
2024 GLE 580
Tire Rotation
First car I've had with different size tires front and back. Obviously no rotation front to back but should you still rotate left to right?
Old Jun 9, 2019 | 03:23 AM
tinman831's Avatar
2020 GLE
That would depend on the tire. If the tire is only directional, you can swap left to right. If the tire has a “this side facing out” requirement, then you can’t swap.
Old Jun 9, 2019 | 09:39 AM
marchgroupinc's Avatar
2020 GLS580, 2023 Corvette Z06
I disagree with the posting that said if your tire says this side facing out you cannot rotate.Yes you can. However if the tire is directional (one way ROTATION indicated usually with an arrow indicating only ROTATION direction tire can rotate) you can rotate left to right etc. but you need to remount the tire on the rim to ensure the correct direction of rotation.
Old Jun 9, 2019 | 11:17 AM
tinman831's Avatar
2020 GLE
Yeah I probably could have clarified that a bit better. That’s what I get for posting at 3am in the morning.
