Battery Tender
Old Feb 12, 2020 | 03:34 PM
Henry Stark's Avatar
GLC63S
Battery Tender
I plugged in my battery tender last night even though it probably didn't need it and after charging for about two hours I received an alert from the Me app that the battery was critical? I then I had to manually unlocking the door by pressing the unlock button then had to push the start button several times to get it to start? I left the charger on over night the charger indicated more charging was needed but the app now says battery charged? I know there was a recent over the air update has anyone experienced similar symptoms?
Old Feb 12, 2020 | 04:56 PM
Hurricane1938's Avatar
GLE450W4
I had a long visit today with the Concierge/delivery manager at my dealership here on Long Island going over several issues. I asked him about using my battery tender while I'm away for one or two weeks. He suggested that I remotely start the GLE from out-of-town and let it run the full 10 minutes, and do that once or twice each week. Interesting suggestion.
Old Feb 12, 2020 | 06:32 PM
IconBycon's Avatar
GLE 450
What is the brand and model of it?
Does it have different operating modes?
Old Feb 12, 2020 | 07:30 PM
Bluehinder's Avatar
GLE580
Does this car use a lithium battery? Does the 580 use a lithium?
Different chargers needed, like BMW.
Old Feb 12, 2020 | 07:37 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Trickle charging
The 12V battery is AGM, I believe.
Old Mar 20, 2020 | 04:57 PM
stealth.pilot's Avatar
2022 Mercedes EQS 580
Does anyone use a battery tender? With the Corona situation and my wife being pregnant we are not going out much. My wife's GLE isn't being used at all.
Should I plug it in with my Porsche 12V battery tender which looks the same as the CTEK one that Mercedes also sells?
https://www.mbpartsstore.com/oem-par...AaApM_EALw_wcB
Old Mar 20, 2020 | 11:46 PM
Anyone?
Old Mar 21, 2020 | 07:48 AM
tinman831's Avatar
2020 GLE
Originally Posted by stealth.pilot
Anyone?
It should be fine.
Old Mar 21, 2020 | 12:35 PM
Originally Posted by tinman831
It should be fine.
thanks. Will give it a try.
Old Mar 21, 2020 | 12:44 PM
tinman831's Avatar
2020 GLE
Sorry for the brief reply earlier. I have the same Porsche charger. I only tested it briefly for a few minutes and it worked. I didn’t leave it to charge for an extended period of time but it should work.
Old Mar 26, 2020 | 07:28 AM
robert c's Avatar
ES350 E300 GLE350 GMC3500 Duramax
[QUOTE=stealth.pilot;8012882]Does anyone use a battery tender? With the Corona situation and my wife being pregnant we are not going out much. My wife's GLE isn't being used at all.
yes CTEK and Granite digital 25 watt both work with AGM batteries and are fully “Automatic”
Old Apr 4, 2020 | 10:45 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
So some W212s do not have trunk batteries? Weird.
Old Apr 4, 2020 | 10:58 AM
robert c's Avatar
would not occasionally start a vehicle without using it. I am using Granite Digitals on my E300 and my Duramax 3500 both are not being used due to the recent conditions. Also use them on my show cars which are not being used either. Don’t have to worry about putting the wrong charger on wrong battery. Also CTEK use the same technology. The GLE is my only driver so the battery is staying charged.
Robert
Old Apr 4, 2020 | 08:44 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
[QUOTE=Henry Stark;7979164]I plugged in my battery tender last night even though it probably didn't need it and after charging for about two hours I received an alert from the Me app that the battery was critical? I then I had to manually unlocking the door by pressing the unlock button then had to push the start button several times to get it to start? I left the charger on over night the charger indicated more charging was needed but the app now says battery charged? I know there was a recent over the air update has anyone experienced similar symptoms?[/Q
I haven’t used a tender but started getting that message every time my car was parked a few days without driving. After a few weeks of the same, the dealer diagnosed it as a defective battery. They replaced the battery and some other glitches went away.
