Hate The Run Flats
Old Jun 11, 2020 | 07:12 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
19" tires undersized
Originally Posted by Cbc200
There are tyres available, 255/60/19 tyres match the outer circumference of the tyres that come with 20’ and above wheels.
It just seemed odd to me that some GLE’s (the ones with 19’ wheels) have tyres with a smaller circumference to the rest.
I have posted about this many times in various threads. Yes, it is odd and seem illogical. Here is an OD comparison:
255/50-19 - 29.1"
275/50-20 - 30.8 - 31.1"
275/45-21 - 30.7"
315/40-21 - 30.9"
For the 19s a 255/55-19 (30.0") or even a 255/60-19 (31.1") would be better. Anyone with 19s should up the size when replacing the tires. The stock ones look really puny.
Old Jun 12, 2020 | 09:36 AM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
255/50-19 - 29.1"
275/45-21 - 30.7"
315/40-21 - 30.9"
Wouldn't that throw off the speedometer ?
Old Jun 12, 2020 | 02:48 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Originally Posted by Ron.s
Wow....My build in early April 2019 is in the 70,000’s-I ordered in November 2018. Some of the very early builds had options not available when full production began....might explain the tires.
Went and looked, build date on the black label in the drivers door jam is 04/19
Old Jun 12, 2020 | 02:52 PM
Tires and speedometer error
I don't have a definite answer on whether the speedo in each vehicle is individually adjusted for the tires it is supplied with; that may be the case. Speedometers are never entirely accurate anyhow based on temperature and other factors.
In Europe it is illegal for speedometers to read low, so most come from the factory reading high; my M4 is 2 mph high at most speeds. I have not found that to be the case with the GLE. The difference between the stock 19s and the next size up (255/55) is only just over 3%, so not huge.
