Aftermarket 21" wheels? Tips?
Old Jun 21, 2020 | 10:52 AM
Ducatisti's Avatar
'12 Ducati 1198S, GLE C292
Looking to get a set of 21" non-oem wheels on my GLE350 (Arrives in October)
I think most of the OEM wheels are a bit dull. Comes with black multispoke wheels for summer.
Any tips?
Old Jun 21, 2020 | 11:28 AM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
How much do you want to spend? AMG body with staggered tire, assume yes if you have 21’s?
Try Tire Rack for a good start. They will supply the Conical style 15mm bolts that you will also need. There is at least one other source for bolts, probably lots more a year after I checked. CariD has a huge selection but don’t carry a lot of them and they don’t sort by wheel width & offset so it’s cumbersome. Then there is the vendor section on this Forum with lots of the Premium wheels. If you have the AMG body with 21’s and want to get close to wheel width and higher offset the selection is limited and hard to find. Mine has 9” by 20 and there were few. The 10 by 21 & 11 by 21 will be even harder if at all possible. If you are also buying tires then there may be more options. Good Luck!
Edit...forgot you are in Norway So go to 20” for winter and try the new Michelin....Michelin Pilot Alpin 5 SUV. 275/50 R20 113V. Great tire unless you want studs
