Help with Trackpad
Old Aug 9, 2020 | 04:11 PM
JustBlessed's Avatar
2025 e450
Help with Trackpad
Sorry if I sound like I’m complaining but I’ve gotten some really good advice and tips from you guys.
I’m having a problem with the trackpad. Let me say I’ve changed the settings regarding slow, Med, and fast.
first off- every time I grab my cup from holder it always changes the radio station. I’m obviously unwittingly touching the pad.
also, I must be doing something wrong when it comes to changing the radio station via the pad. Why is it such a pain in the *** to switch/find a radio station? I have favorites stored but still a pain.
honestly I just think this pad is not good and the wheel was probably MUCH better.
Old Aug 9, 2020 | 05:03 PM
darlop's Avatar
a
Your supposed to switch stations by swiping the top middle of the pad where the arrows are.
The design of the center console is poor in general. If you have anything in the cupholder it makes it really hard to get your phone in and out of the wireless charging pad. And the pad is just barely big enough for plus sized phones. Then on top of that the plug for carplay/android auto is right next to it which leaves no place to keep your phone when its plugged in.
Old Aug 10, 2020 | 12:14 PM
2025 e450
ok so at least I’m not the only one noticing this.
Old Aug 10, 2020 | 12:49 PM
Philamg's Avatar
GLC 450
The pad should be dispatched and replaced by dial like on BMW'S
Old Aug 10, 2020 | 02:56 PM
darlop's Avatar
a
I wouldn't mind that. The only advantage of the pad I can think of is that you can write on it. But there are plenty of other ways to enter info so I think we can do without that.
In fact I would like more dials in general. There is a reason why cars have them. They kept the volume dial which is good. The AC temp should also be a dial. Its a lot quicker to turn a dial then press a button for each degree. Sadly in a few years we aren't going to have any physical AC controls anymore...
Old Aug 10, 2020 | 06:47 PM
buntym's Avatar
GLE 350 (V167)
The sad part is that you can actually "write" on the dial with BMW's new iDrive 7 system.
Old Aug 10, 2020 | 06:58 PM
monwen's Avatar
bmw 535i xdrive
Pretty sure you can write on the ‘20 GLE trackpad as well. I never use it because I’m left handed.
Old Aug 10, 2020 | 08:24 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
My trackpad occasionally goes rogue and stuff starts flying across the screen when I'm not touching it. I with there was an option to just disable it...very poorly executed idea.
Old Aug 11, 2020 | 12:05 AM
darlop's Avatar
a
One thing to try is turn off "Touchpad tap" under control settings. This makes it require a hard click to select something rather than just a touch.
While we're on the subject I just realized that there are only 8 buttons on the main screen. They should show these all on the screen at the same time rather than having to slowly scroll through them.
Old Aug 14, 2020 | 09:49 AM
2025 e450
I’m gonna try to **** off the tap.
a cool feature on the Jaguar system lets you recreate a custom home screen and resize all the icons. I was able to make screen with everything on one screen
