Update on serious issue
Hope the info is helpful to someone!
Incredible at this price tag.
a lease car is a rental car. You wouldn’t put up with a defective car from Avis or Hertz, so why tolerate it from anyone else?
I would start by questioning the painted wires story on its face. I don’t see how painted wires would cause a problem? It’s possible that paint could cause a short circuit but that wouldn’t be intermittent. More likely an electrical component might be damaged but that wouldn’t require replacing the wires. Now if paint got on the exposed wire ends before assembly that’s possible but could be removed easier than replacing them.
Something doesn’t add up, IMO.
After the car is painted, I assume there is a process to remove the paints around the grounding point to allow for a good contact between the wiring and the chassis.
I would think a painted over grounding wires wouldn't cause any issue if the connector is making good contact between it and the chassis, but if the paint on the chassis around that grounding point wasn't removed when installing the grounding wires, it would cause issue as the wire/connector isn't making good contact.
(not mercedes but just grounding in general)
Cars use the car chassis as the grounding (negative). Instead of having all the wires from all the electronics connected to the battery negative, they all connect to the car chassis. Then near the battery, there is a wire connecting the car chassis to the battery negative terminal.
In order for the grounding point to work correctly, it must have good contact between the connector (the metal "ring" you see in the picture) and the car chassis. If there is an layer of paint in between, the wire connection will work poorly or not work at all.
Most factory (I believe) after painting the car (since all wires are connected after the painting), they have a separate process to remove the paint around the grounding point so that there is a good contact between the wire connector and the car chassis. So I believe what most likely happen in your case, is that process wasn't done correctly (or possibly missing all together), which create a poor/non-functional grounding point.
