Most underrated/favorite options
My impression after driving the SQ7 and GLE without Acoustic, back to back was that the Audi was somewhat noisier, but I attributed it to the road surface, not the car. Both had Pirelli tires.
Wind noise on the GLE's I have driven is low below 70mph, similar to Audi. Neither is as quiet as a Cayenne with its Insulated Glass.
My only experience with Acoustic Package was long ago (September), and quieting road noise intrusion seemed to be its biggest contribution. I ordered it because it allows more enjoyment of the 3D Burmester (which didn't get ordered before my order was locked - drat!).
After the turbo lag, the SQ7 makes a loud and sudden racket, augmented with speakers, which also use noise-cancelling technology. This may make light footed driving seem quiet in comparison. I like the noise-cancelling - don't think M-B uses it.
It might be a surrogate for a tin foil hat, if that's your style, though
My wife is tired of my dragging her to dealership to look and drive cars. She says visiting a dealership is as painful to her as it is to me to deal with attorneys, so we spent about an hour in each car today going over all the pros and cons or each: driving, parking, playing with all the controls, climbing in and out of every seat. I wanted to make a decision today and come home with one. Each has great and bad points.
After all that we are leaning towards the GLE (more me than her) because of what we want out of a car at this time, if the leather is fixed. But the Audi so close.
I test drove them both but it was like 2 weeks apart. I remember the 450 was sportier(obviously) but I didn’t spend enough time in comfort mode.
Likes and nice features:
- The colour and data density on the instrument cluster. Cayenne was austere and just ‘white’.
- Great interior lighting
- I still get to have the grab handles!
- Sueded headliner and material selection throughout.
- Physical buttons and switches
- One option/ability I wasn’t expecting is the ability to display gasoline prices on the Nav screen.
- Windshield washer nozzles integrated into the wipers
- Wheels fill the arches perfectly.
Things I wish they’d change:
- Lacklustre (I’m Canadian) thigh bolstering
- Drive mode buttons are one-way - ie. they don’t work up and down, you just cycle through the list - why? And when you stiffen the dampers, it puts the notification in small font on the far right of the screen. When I change the air suspension, how do I know the level I’m currently at?
- Sound stage on the ‘base’ Burmester is very focused on the very front of the vehicle. I have the fader at -3.
[+] the MercedesMe app is much more capable than PorscheConnect. I doubt I’ll use the remote starter, but nice to have it nonetheless.
[-] Feels, drives, and turns like a ‘big’ vehicle.
Coming from owning the last three versions of the Cayenne S and now owning a 63S, some likes/dislikes:
When I change the air suspension, how do I know the level I’m currently at.
The Drive mode determines the driving height so any change like lowering the rear with the hatch switch, lower on entry or using the center console rocker switch are only temporary. I haven’t checked the manual but AFAIK the AMG only changes up or down about 1 inch. It drops an inch in S modes & at 70mph in C mode. Raises an inch in Trail, maybe also in Sand mode. The GLE 450 moved up higher in T so I might be wrong on the AMG.
I noticed this feeling, my 2020 GLE 450 that had light steering and felt smaller/lighter. The AMG steering could benefit from a slightly lighter feel. The GLE 450 steering intensity increased at speed...maybe a better all around solution. In another way it might be better after getting used to the heavier steering...I noticed less tendency to “wander” on a long freeway trip. It seems to hold a line better.
If your Canadian build is like the US, you should also have adaptive sway bars that are factored in to the suspension characteristics in different driving modes. They also keep the car flat in corners like your Porsche or our Audi.
My issue with the suspension settings were two-
1. The suspension resets to C mode when the ignition is cycled back on. A vendor may now have a solution.
2. The lower on entry also resets so it’s a pain to set it just before stopping. With running boards & even without it’s easy to get your pant legs dirty on exit. (My wife’s only complaint)
I bet they would come wrinkled and the wrong color though. Haha
- I have a new 2021 63 S. I suspect the features all work identically, but that the packaging of options varies between the US and Canada.
- Point taken on the bolstering. I’ve had the 18 way seats in the Cayenne’s before (thigh bolsters are adjustable), so I think it’s just a matter of taste.
- I read the manual a bit last night and you’re right in that the height adjustments aren’t “permanent”. Again, a difference between manufacturers that isn’t a big deal. I believe the + setting adds 2.2”, and the - setting drops it 0.4”.
- As for drive modes, the torque is so strong that I leave it in comfort except for the exhaust valves!
I tend to use the manual switches for this stuff to minimize the distraction. - I think part of the “big” feeling is the height of the hood, particularly at the front bumper.
I pulled my supplement again and noticed the different ride heights from the GLE 450. I had the speed wrong also...not 70 but 75 to lower in C mode.
Some of us are still trying to figure out if the AMG adjusts the active sway bars mechanically or by scanning with the camera like it does with E-ABC.
There are almost too many options and menu changes from the GLE 450 that also seemed a little too complicated drilling down to find info, IMO. There seems to be some added redundancy now and it’s like they just stuck some AMG options into an already complicated MBUX system. It would be better if we could drag and drop some menu selections similar to a smart phone.
Depending on your location in Canada you might have more wide open roads than in the Western US. There are some roads in Western Canada and even more in NW Canada that would be a lot of fun to drive with the AMG S/S+ settings. (But then I remember the road signs in Alaska citing Moose/Auto incidents)
I wonder if the Star button on the console would serve this function.
