gle 350 awd
Old Mar 9, 2021 | 11:32 AM
Mcfancy14's Avatar
350 GLE 4matic
gle 350 awd
Is there an explanation for when this function is in effect ? Does it only operate below certain speeds ? Does it need to be activated each time, and if so , how? Not much in the manuka I could find on good details. Tx
Old Mar 9, 2021 | 12:12 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
350 4Matic system
Yeah, you won't find much in the manuka . But, here you go:
"In the four-cylinder models, the transfer case of 4MATIC all-wheel drive directs the drive torque to the axles in a fixed 50:50 percent ratio. Spinning wheels are braked by braking intervention at the relevant wheel. Other functionalities such as Start-off Assist and Downhill Speed Regulation (DSR) support the driver both on and off the road. Decades of experience with the system by engineers at Mercedes-Benz are reflected in the dynamic performance and comfort of the GLE. This is achieved by finely-tuned interaction between 4MATIC and the electronic braking, control and traction systems."
The 6- and 8-cylinder models use a much more sophisticated system (Torque on Demand) with fully variable front-rear torque distribution via a transfer case with an electronically controlled multi-disc clutch. This improves handling and traction without extra brake wear.
