Tire rotation
I'm watching tread wear to decide if it will be worth a dismount/rotation as the miles go on.
On Mercedes MO tires they are designated MO-S (silent).
In the past, M-B has specified higher tire pressure in the rear, typically indicating that their designs prefer higher roll stiffness at the rear. This has been my experience at the track, too. And IMO negative rear camber was somewhat excessive for a highway vehicle, but also indicating a need for more cornering bite at the rear.
Now, they specify higher tire pressures in the front. It also appears that the negative rear camber has decreased with the new model. Together, this may indicate an increased roll stiffness up front, and the offset (tires more outward on the 167's) is part of that.
Taken together, the new chassis is such an improvement over the old, that I'll accept the differing offsets.
But all else being the same, I haven't liked staggered wheels, or different offsets, because of the tire rotation issues.
My hope is that the rears won't wear the inside of the tread as fast with less camber, which was my limiting tire life issue.
