20 or 21 inch wheels ?
So….
Yes they look good, although I’d argue 20s look classy and 21s look a little too over the top for a family SUV, but you do take a big hit on all areas mentioned.
Oh and forgot the obvious, they cost an arm and a leg and mounting tires are a pain in the ***. While most tireshops can handle 20s, for 21s you need specialized equipment - more hassle.
So….
Here's a (lengthy) video about their design -
The tires' weight certainly does affect the rotational mass, and I don't know if the lighter AMG wheels offset that penalty.
Z-rated tires with MO-1 specifications, may overcome the disadvantages you state, and justify their price.
I think the fat tires affect fuel economy, though, probably because of their rolling resistance, and maybe drag coefficient.
Here's a (lengthy) video about their design - https://youtu.be/nF__XxFRCjg It's actually pretty interesting.
This is probably for 2 reasons, first and foremost is the cost, the $3000 package wouldnt be able to cover the cost of extremely lightweight mono block forged aluminum wheel set (that would be 3x the cost of the package), secondly, the car at 5000 lbs (and with a 7000 lbs tow much more than that) can put a tremendous amount of load on the tires and wheels. Those wheels while looking like other AMG wheels have to withstand to stresses far more than a 1500 kg track car will in a race track pulling 1.2 lateral g.
Also, you buy a GLE, I'm sure you want to be able to drive in snow and ice, correct? 315s on a 5000 lbs car? Good luck with heavy snow fall. Even 275s is probably widest you want to go. The thinner the tire, the more it will cut through the snow and allow you to steer/brake/accelerate (incline/decline) better. Been there, done that. I have 335 section snow tires as well as 285s and I have had 265s and 245s in other cars. Those aspects I mentioned are dramatically worse in the 335 car. 285 is barely driveable in deep snow.
Fortunately, my Go-To winter tire, Nokian R3 SUV, is now available in that size. They have been incredible on snow and ice, but smaller 255 and 295 sizes.
So the dilemma is to try the legendary Nokians in fat tire size (would be my 4th set), or get another set of 20" winter wheels. Then there's the seasonal storage problems.
So, for this thread, this is just another question to answer in choosing between tire fitments.
Despite these wonderings, I am pleased with the 21's on our AMG53. The car deserves the grip. Actually, it could use more.
For the ultimate, practicality not-an-issue experience, I should have gone 22" UHP tires and a set of 20" winters.
So….
My guess is that your experience is also Brand-specific. Some brands have gradual breakaway, others are abrupt.
On the track, 21s are inadequate for the 2 1/2 ton GLE. 20's were fine for hustling along a favorite twisty, but they get hot and slippery after 10 minutes at .75 G's. So if performance is your goal, other things matter.
I chose 21's primarily because of better availability than 22's. AMG wheels are VERY light and strong BTW.
