Does your Mercedes V8 use oil?
“The cylinder walls of the engine block are treated with a spray-in liner that Mercedes calls Nanoslide. This coating is designed to help reduce cylinder wear by holding oil in place thanks to its micro-porosity, while the friction reduction helps with fuel economy. It is also a very thin coating, which helps give these benefits without the weight penalty materials like this have added in the past.”
