Help with a 2022 GLE build
!. is the 450 and 53 equally quiet at cruising highway speeds?
2. Is there much ride quality difference between the 21" multi spokes and the 22" 5 spoke? also what's up with those black inserts on the RXT 22"? It almost makes it look like a hubcap ( pic attached)
3. Is the air balance with ionizer worth it? not wanting the scent, but we all have allergies in our house so I'm wondering if the air is that much better?
4. How much does the airmatic with ADS help with handling? is it pretty significant over the standard steel springs?
Thanks in advance for your help!
Yes…both are very quiet except on new seal coated roads there is tire noise.
Can’t compare 21/22 but less tire sidewall as well as tire pressure will always have some effect on ride. The 20’s offer the softest ride but the 21/22 are better at speed on curves with less sidewall flex. I have 21’s on my 53 and run 20” winter tires.
Not worth it, IMO.
When spending the money for a 450, Airmatic is a must, IMO. Airmatic will give you a better ride and the option for soft vs firmer suspension. Your wife might like the softer C mode around town and Sport mode on a trip if you get into curvey roads-if she is an aggressive driver or if you drive. With Airmatic you can set up the I mode the way you like it. I had 3 of 4 settings in Comfort mode with the suspension set to Sport. The best suspension is included in the Dynamic Plus Package package available on the GLE 53. It softens bumps and the Active Sway Bars keep the car flat in corners. It’s not quite as soft as the GLE 450 Airmatic but not as harsh as prior AMG’s. The only issue I have with mine (21’s &DPPkg) is that the 21’s are a lot more finicky-keeping a softer ride quality vs tire pressure than the 20’s. My 21’s also require more attention as temperatures fluctuate during the year. I recently did a Nitrogen conversion to see if that might mitigate recent air pressure swings of up to 5-6 psi.
