Speedometer Inaccuracy
Old Oct 27, 2021 | 02:22 PM
Swordfish99's Avatar
2021 GLE 53 Iridium Silver
Do you guys notice your speedometer is out a lot if you are driving at highway speeds? Mine is out about 7-8 km/hr when driving 110 km/hr. Mine were out with the original tires and wheels and I was hoping the new winter wheel package would fix it but it is out the same amount...
Old Oct 27, 2021 | 03:19 PM
mikapen's Avatar
Mine is pretty much the same reading as my radar detector and Waze. Mine's a GLE 53 with 21's.
How are you comparing speeds? What size tires? Do you show slower or faster?
Old Oct 27, 2021 | 03:30 PM
I also have 21 inch tires on mine. I have my radar detector (Redline 360) and portable Navigation device and both show the same however the car says I am going faster. The faster I go, the more it is out.
Old Oct 27, 2021 | 04:03 PM
superswiss's Avatar
2019 C63CS
That's normal. Speedometers don't actually measure the real speed of a car. They measure the rpm of the wheels and then convert that to speed based on the tires' circumference. This circumference constantly changes with the weight of the car, ambient temperature, tire pressure and tire wear, so to avoid speeding tickets, most speedometers read higher than your actual speed. It might be more accurate on a cold morning when the tire sidewalls are still stiff, than on a warm afternoon with the tires warmed up and the sidewalls being softer. Radar detectors and your phone apps use GPS to measure actual distance travelled in a given time, which is the real speed of the car, however, even radar detectors may intentionally read high to keep you from getting speeding tickets, especially as many newer radar detectors can factor in speed to decide when to be silent and when to alert.
https://www.roadandtrack.com/car-cul...ters-accurate/
Old Oct 27, 2021 | 05:48 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Mine is like yours…so accurate I keep scratching my head. I have the new R7 Uniden Radar Detector and it is always exactly the same or within 1 mph when the RD needs to catch up. I have checked mine against the roadside Radar and had a nice policeman pull me over to confirm the accuracy at 10 over posted. No ticket just a warning👍
Old Oct 27, 2021 | 05:57 PM
MBguy013's Avatar
Veteran: Marine Corps
2021 GLC 300 4Matic
Originally Posted by Ron.s
...had a nice policeman pull me over to confirm the accuracy at 10 over posted...
Old Oct 27, 2021 | 06:23 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Speedometer accuracy
Mine seems pretty accurate (21s).
Old Oct 27, 2021 | 06:30 PM
Philamg's Avatar
GLC 450
In the UK all speedometers read OVER the actual speed, it is illegal for them to read under, the over reading increases the faster you go.
Old Oct 27, 2021 | 07:12 PM
js_cls's Avatar
Pretty typical for German cars, my BMW’s are usually 3MPH over the actual speed.
Old Oct 28, 2021 | 08:35 PM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
Mine is dead on accurate when checked against GPS…all speeds.
Old Oct 29, 2021 | 07:10 AM
Zeusmotorworks's Avatar
2022 GLE 450/2020 Gen 2 Raptor/few others
21's (all seasons) dead nuts on per GPS
Old Oct 29, 2021 | 10:40 AM
HotRodW's Avatar
2021 GLE450
Our GLC and GLE are both spot on, unlike my BMW's which consistently indicated 79mph when cruising at 75. Our Audi and VW speedometers were accurate, too.
Old Oct 29, 2021 | 03:00 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Mine is very accurate
Old Oct 29, 2021 | 07:26 PM
CMFUSA's Avatar
GLE350 (2021), 991.2 (2019)
Just checked mine. Dead on with 21 Pirelli Scorpions.
Old Oct 30, 2021 | 08:16 AM
EddieKBG's Avatar
2021 GLE450
I have 22" wheels and it's 5-6mph slower against both radar detectors 🥺
Old Dec 3, 2023 | 12:11 PM
Robm974's Avatar
2022 AMG GLC 43 Coupe
Were you able to get your speedometer fixed? Mine is out a similar amount - very annoying- and the dealer said no sensor going off therefore nothing to fix.
Old Dec 3, 2023 | 12:40 PM
TexAg91's Avatar
Modern speedometers are computer based, sensors count the wheel revolutions per second and multiple it by the tire size (specifically the tire diameter) to calculate speed in MPH/KPH.
If your speedometer indicated speed is higher than your actual speed, it means the computer is using the wrong wheel size (diameter) for what’s actually on the vehicle (using a smaller tire size). The dealer should be able to check the tire parameter values being used in the vehicle’s software to verify they match the actual tire size on your GLE. I suspect they don’t match. Perhaps someone changed out the rim tire combo being used and didn’t update those values in the vehicle software?
Old Dec 3, 2023 | 11:56 PM
Robm974's Avatar
Originally Posted by TexAg91
Modern speedometers are computer based, sensors count the wheel revolutions per second and multiple it by the tire size (specially the tire diameter) to calculate speed in MPH/KPH.
thanks for your response. I had the car (GLC 43 Coupe) into the MB dealership where they said there was nothing they could do. I plan to go back and ask them to pursue it further, seems very strange to me for a high end car to be out 5-7% on the speedometer.
