Brake Pad Replacement 2020 GLE DIY
Old May 18, 2024 | 06:49 PM
mikapen's Avatar
Originally Posted by FireRx Captain
Nope, and you talking to the owner of five Mercedes in the last 25 years. I've always done my own minor maintenance. When it something I can't handle, I take it to the Dealer. Simple as that!.
I was thinking that you based your not going to the dealer for a brake job based on a $900 price. Based on what you said.
Thanks for clarifying.
We don't know what the $900 covered anyway.
Old May 18, 2024 | 07:06 PM
FireRx Captain's Avatar
2020 GLE 350 4Matic, 2016 E350
Originally Posted by mikapen
It's probably a good idea to get a quote from the dealer, for the services you want, and base your decision on that. Instead of an Internet post.
If I told you it only cost $800 if you have the dealer do it?
if it was only $800 buck, then yes I might. it would only say me $200 doing it myself. that's Pads and Rotor both.
Old May 23, 2024 | 11:03 AM
KrustyKustom's Avatar
2021 V167
Anyone have the WIS torque specs for the caliper slide bolts and the caliper bracket? My Xentry only goes to 2019.
tks
Old May 29, 2024 | 06:23 PM
krzyoldgy's Avatar
2020 GLE 450 4MATIC
Originally Posted by TEJ SIDHU
would anyone happen to have the part number for the caliper bolts? And the torque spec for those please!
Just ordered these part numbers for Brake Pad replacement of my GLE 450.
Front upper and lower are different (I think the GLE 350 has different brakes)
2 x Disc Brake Caliper Bolt 000-990-59-08-64 (front)
2 x Caliper Support Bolt 910105-014005 (front)
4 x Caliper Mount Bolt 910105-012010 (rear)
I'll use EBC YellowStuff pads from Perfect Brakes
https://perfectbrakes.com/automotive...43#prettyPhoto
Old May 29, 2024 | 06:48 PM
2021 V167
Are you going to use OEM rotors?
Old May 29, 2024 | 07:11 PM
krzyoldgy's Avatar
2020 GLE 450 4MATIC
The rotors are in very good shape, I'll machine them ($30 each) for a smooth surface and re-mount.
If I see that the rotors' width goes below spec (which I doubt), then I'll need to replace them.
