22” Tire Size Replacement Costs
I was just browsing Tire Rack to see if all-seasons were available in the 22” OEM tire sizes and was shocked at how expensive tires are in the 22” OEM tire size.
The only all-seasons available costs $900 a tire lol. The “normal’ summer tires costs $600 to $900 per tire.
That’s just crazy…. Not sure what’s going on with this size. I assume—based on the fact that they’re so expensive with most of them on back order—that this size is not used much.
Received 1,637 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
Unfortunately, the only Mercedes size where several manufacturers make a good selection of tires is 20".
2021 AMG GLE53 | 2013 SLK350 Sport
The 22” OEM size is: 285/40R22 and 325/35R22. You can search Tire Rack by make and model and it will bring up the available tires for that size.
$4,000 for tires that might only last 15k miles lol. That is more expensive than 22” HRE Flow Form wheels, which are, as of now, $3500 for four per the quote I just received. Something is majorly wrong with this picture.
Has anyone tried using a slightly different size tire that is more common? It would have to be similar to the overall diameter but may be narrower or wider.
I know some people with staggered setups end up going square without issue on AWD cars.
Received 1,032 Likes
2024 GMC Canyon Denali..... 2018 Audi SQ5
I run a square setup in winter using the factory front tire size all around on 20” wheels. Most people wouldn’t notice any difference in normal driving. The taller sidewalls from 21” to 20” wheels let the sidewall flex more in quick cornering turns at speed. It’s a slightly different feel but almost imperceptible.
Frenetic (07-01-2022)
I did a search for tire sizes vs car make and model and there’s actually a lot of tires available with XL rating factors, including all season, that are relatively cheap.
Anyone know why they don’t show up for a model search? Is it the speed rating? Aren’t our cars locked at 112 MPH anyways?
The top speed is higher than 112-on the GLE AMG 450-130; your GLE 53 is 155.
Also, if you go to tiresize.com you can enter our size tires and it will show the closest size equivalent. I’m going to see if there are alternative sizes that fits our wheels with a greater and cheaper selection of tires.
Here’s a good site for tire comparisons…All the info you need. Unfortunately there aren’t many options for 21’s.
http://www.rimsntires.com/specspro.jsp
After some research, this is probably the best in terms of overall diameter and width matching: 275/40R22 front and 315/35R22 rear. The differences are just 0.3 inches for diameter and 0.4 inches in width. Choosing this size brings up Continental Premium Contact 6 SSR, which costs roughly $1,900 for a set. Not bad. This also brings up a relatively cheap winter tire at $1,500 (Continental Wintercontact TS).
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1626/5b24fca5_ba78_45c5_b55e_4f7460e74cbd_79aaf5ce32bec7f78b5d505ae9fc375a71ab77ff.jpeg)
That's quite an assortment of sizes and ratings. I'd be careful about mixing without some further research.
Also, try a source other than Tire Rack. They don't offer a complete selection.
Maybe they will, now that Discount Tire has bought Tire Rack.
Edit: I tried posting the link but it won’t work like that. You have to select year, make, model …etc.
Dunga, one thing I noticed is that the two less expensive ones aren’t XL rated. Might explain why they’re cheaper, unless I’m missing something. The GLE needs XL rated tires I believe.
For the choices that came up for me, I entered 2022 GLE 53 Coupe.
'21 GLE 580, '20 Cayenne Turbo
Yesterday we installed the Scorpion Zero all seasons on my wife's 580, and they're feeling great so far. Although they're backordered everywhere, I found them on eBay (very recent 2022 production, even). Not much more expensive than the PZeros and have a bit more tread wear.
Tire prices are just bonkers right now. While I’m not an expert in these matters, I believe high oil prices, high inflation and general price gouging are all influencing what we’re seeing when it comes to new tires. I checked a quote I got for 22” wheels for my BMW in 2020 and they were 30% less back then! $425 vs $550 for the fronts.
Have you checked your dealer for availability and pricing?
