Towing with U-haul trailers (no brakes).
Has anyone done this? What was your experience?
Is it doable?
Thanks,
*Edited to remove statement about U-Haul auto hauler as they have surge brakes
The answer to the question does not depend on model year for an MB SUV. All generations of the W/X16* platform are a solid towing platforms. And off-road platforms but that is a separate thread.
167 and 166 have a bit more than a 7k lb tow rating. 3k lbs is less than half of the rated towing weight.
I towed a 3500 lb boat last week, and have done with a 166 for the last 4 years. No trailer brakes. The system is solid as a rock.
Air suspension does not change the equation. The manufacturer rates the vehicle and gives instructions in the manual. If you tow under the rated weight and follow the owners’ manual you will be successful.
Avoid overthinking this.
There are dozens of threads and hundreds of posts on towing with 164 and 166 including with air suspension. 167 brings nothing new or different on this topic.
I towed my E39 M5 at just over 4k lbs with my ML550, then my X5 45e, and now my GLE450 without issue.
Just make sure you test the trailer lights. MB electronics can sometimes not play nice with the LED lights U-Haul uses.
Edit: I avoid the tow dolly - I find the hauler to be more secure and less troublesome. Worth the added cost IMO.
Although the car hauler comes with the surge brakes whereas the tow dolly does not. So if I want the hauler, I have to borrow her car. I suppose I could take her along...
Depending upon the car, the trailer configuration and the tie down mechanisms, that might mean you have to back onto the trailer.
I've towed a 6,000 lb RV with the 164 and 166 ML's and I agree with @chassis that they are really capable tow vehicles.
Just balance the load and inflate to the gas cap pressures and you'll be fine.
I once towed an FJ45 on a U-Haul car hauler. Before they would rent it to me (I think I wasn't on the automatically approved list), I had to describe the Land Cruiser so they could get clearance from the home office for my ML and the loaded trailer. Home office said okay. Ask ahead.
I'm assuming you have the factory hitch.
Also, always check the tires on u-haul equipment. I have had bad ones more than once and refused the first trailer offered.
