Two coolant questions
Had same issue with my GLE. Took it to dealer they filled it up to where yellow line is. Been fine for a year now no yellow light has come on.
Your S/A will be happy to add to your coolant if you’re near by.
and still... here is what manual says about marker bar. I don't see 100% match between that black hose sleeve and this picture:
Also, the dealer filled my car up to the same level as what SigP shows, but that level was when the engine was warm/hot as I just pulled in. I checked it later with a cold car and the level had receded down the seam.
Also, I watched the dealer open that cap while the car was very hot. He slowly turned it until it hissed then opened it up fully. That’s not something that I personally would do.
