Mercedes Navigation vs Google and Apple Map Nav
If you happen to read the original post, I went through every setting the first time it happened and nothing changed. It’s a natural thing to do, right? However, I kept it on SHORT as the default. Explain to me how that setting would send me the long way around? I can understand FAST sending me the long way around because it thinks there’s a traffic jam somewhere. Again, when this first happened it was also on short. I changed it to fast and the 100+ mile re-route never changed. I’m just curious why you think that setting would make a difference?
I can’t explain what’s wrong with this car. I wouldn’t bother wasting my time with these posts. I’ve never had a car that had this many issues so soon after I purchased it. It’s unfortunate as I do like it.
There are a number of members on this forum that have varying levels of expertise and/or experience and are willing to offer suggestions intended to help others. As a new member you might not be so quick to dismiss suggestions but be more inquisitive if you don’t understand them.You can get some bad advice but it’s up to you to filter out helpful info and deal with it rather than try to judge who’s right or wrong. Most of us have found that the Dealer is the place to get unique issues resolved and the Forum can help prepare you for the visit. User error is one big reason that Dealer Service Departments are skeptical about non mechanical issues. This isn’t about admitting a mistake, but one should always consider the possibility when you are changing settings and also having issues that others don’t have….
I’ve had more “difficult to diagnose” issues with my two Mercedes GLE’s than any other member has reported on this Forum. Being an early adopter has those risks. The approach that worked for me was more along this plan:
1. Report the issue on the Forum
2. Gather suggestions from members; check & test relevant settings; did any similar issue get resolved?; any TSB’s reported? Prepare yourself for #3.
3. Decide on the next step-Dealer visit first or Document the issue with pictures or video. The Dealer needs. to verify the issue if it’s not covered by a TSB or Mercedes Tech Talk bulletin
4. Make the appointment and take a written document along outlining the issue in depth along with supporting pics or video. If a member provided a TSB reference or copy of their Service Receipt (similar issue) include a copy.
5. Report any resolution along with the Service doc’s on the thread you started. I chop off the top showing the personal/dealer info but offer to supply it if necessary.
There is no right or wrong way to do this since some issues are more complicated than others. My point here is first to have a plan. It’s never helpful to debate suggestions because you don’t know which members know more about the subject than you do. Asking questions yields better results. Don’t become one of those PIA’ members that aren’t taken seriously!
Superswiss—with a straight face—said something that was completely false in the LKA thread. He made it sound legitimate with his long posts and I at first believed him, so excuse me if I have some skepticism believing anything else he says. He doesn’t even own this car. It’s one thing if he came here with a reasonable suggestion, but whatever.
Listen I don’t think you particularly care for my posts very much, which is fine, as I don’t particularly like you, either. But I don’t make a point coming into your threads insulting you, I would appreciate the same.
Superswiss may not be perfect but he has been a helpful contributing member for years. I followed his posts on the Audi Forum years ago and would rate him as above average with no hidden agenda. This Forum isn’t about any one person since information here is used by other members.
Unfortunately with all the back and forth and personal attacks, I'm reluctant to post my questions.
"Some people" can ruin a forum.
Go ahead and do whatever you can to force MB to fix it, i dont think anyone here wants to stop you, but the workaround is something you can use in the meantime.
Underlying data for US navigation rates very low in my book while all systems in Europe have no problem finding even small dirt roads.
But traffic re-routes often seem cumbersome and are hard to judge as one has to make the choice which alternate is best at the time. Obviously most all drivers follow the same suggestion, degrading said re-route
I’m not looking for the dealer to fix this as I don’t think it’s fixable, and I wasn’t looking for a fix here, either, but I was just curious if anyone else experienced poor routing, which for me was a 100+ mile reroute for no apparent reason.
In addition to setting preferences for Fast, Short and more, there is an even deeper menu for "Avoid."
When I first got the car and was diving into the MBUX settings, I made some settings that turned out to be at odds with some of the features that I wanted to enable later.
It took some effort on my part to figure out what I had done, but it turned out to be my operator error before I understood the menus.
It looks like you could even avoid an address where you shouldn't be going!
For NAV problems, I'd go back and revisit the basic settings. There are more than I showed here.
All routing can be affected if there is an unintended setting in the "avoid" section of your NAV menu.
Without drilling down to the bottom first, troubleshooting is a waste of time.
The point here is that it isn't always some MB conspiracy to make our life miserable, or inadequate design with either hardware or software, but rather the data that is being received by the NAV. Unfortunately, you can't do anything about that, IMO.
And there, the battle will probably be between the two most advanced players, NEAR {the Mercedes source) and Alphabet (Google).
NEAR has Europe locked up with acceptance by Automakers and Self Driving component manufacturers. In the US, NEAR is the primary source for Fleet operations, and is probably the leader in Car-to-X data sharing.
The advantage (today) is that Google maps are updated more frequently than Mercedes' twice per year, but a Waze disadvantage is that it's crowd sourced, relying on direct input to cancel warnings or police spottings.
Car-to-X is more accurate and immediate, and is a better measure of traffic flow and driving conditions
Example - NEAR is alerted when antilock brakes are activated or when wheelspin is detected, so an aggregate will indicate slippery conditions in a very specific area.
Transportation departments and municipalities are receiving NEAR input for alerts of traffic conditions, accidents, and slippery conditions. That ecosystem is marching forward, and I believe Mercedes has chosen the right partner for their NAV.
Also, NEAR is currently accepted as the reliable source for Level 3 self driving cars, Google or the other candidates are not. Mercedes is the only manufacturer with a Level 3 self driving clearance.
