Violent Shaking at Startup
Old Nov 30, 2022 | 07:32 AM
Frenetic's Avatar
2023 S500
Anyone else’s car violently shake at startup? It doesn’t happen very often but it seems to happen very randomly and it’s very disconcerting. It goes away after I place it in gear. There are no error messages or other outwards visible signs of an issue.
Before the peanut gallery comes out blaming user malfeasance, I don’t believe it is bad gas as I always use premium, expensive fuels and it’s occurred over multiple different tanks of gas from different gas stations. Moreover, it only happens at startup. Other than an occasional weird idle speed/vibration at stops, it drives fine.
Yes, I intend to go back to the god foresaken can’t-fix-anything-in-one-day because they’re probably backed up a mile long with failing cars dealership.
Old Nov 30, 2022 | 01:02 PM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
Call the dealer and reserve a courtesy car. They will schedule you when one is an available.
Old Nov 30, 2022 | 02:27 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
If it happens again take a video.
Old Dec 2, 2022 | 12:21 AM
EL-34's Avatar
2022 GLE 450
This to me is a problem that traces to plugs and/or coil packs. I wish NGK had the brainpower to produce ruthenium plugs for our engines. After that I'd look into new coilpacks. Is there a check engine code? Is the battery ok?
Old Dec 2, 2022 | 10:13 AM
Frenetic's Avatar
2023 S500
No check engine light comes up. It does feel like a misfire, though. The entire body shudders and it feels like the engine is stumbling. However, if I place it in gear, it subsides a lot, but it is still rough. Yes, I’m going to take it in but I don’t have much faith and I damn tired of constantly going back there with no loaner in sight or reserved months out.
Old Jan 15, 2025 | 04:07 PM
Shadedmoon's Avatar
Mercedes C230 1997 W202
Model year of the car? Engine?
Sounds like it could be torque converter-related, more so if early model year car.
The torque converter "locks up" around 50-60 mph / 80 km/h to save on fuel and disengages on load to provide more torque.
This doesn't explain the issue coming up while turning at slow speeds however.
