2020 GLE 350 Code P259F
2020 GLE 350
Hi All!! My 2020 GLE 350 just threw the following code. Any ideas on what is causing this?
P259F Turbocharger "A" Boost Control Position At High Limit
TIA for any help!
TIA for any help!
What other symptoms have you had? How is it running just before and after the code comes? Any recent work done to the engine? Is the battery in great condition? If not be sure to get a new one; these modern engines are very susceptible to low voltage conditions. Have you cleared the code and did it then return?
2020 GLE 350
Good call on the Bat. Something I will check in the AM.
I did NOT reset the code as it was listed as a "Permanent Code". But I will give it a shot tomorrow and see what happens.
Thanks for the reply!
