The GLE loses speed quickly.
Old 05-24-2023, 08:09 AM
yabloky's Avatar
GLE 350
I'm just riding on winter tires))
Old 05-24-2023, 08:44 AM
W205C43PFL's Avatar
Received 2,816 Likes on 2,398 Posts
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Okay nevermind that might had explained it, winter tires are meant to help you stop for example so the rolling resistance is stronger than summer tires or even all seasons.
Old 05-24-2023, 05:07 PM
nguyensteve's Avatar
GLE53 Coupe
look normal from video
Old 05-26-2023, 07:54 PM
mikapen's Avatar
Received 1,650 Likes on 1,219 Posts
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
Originally Posted by EL-34
consider it as a sign of a very healthy engine and transmission. The piston rings are seated properly. Our 450s are 6600 lb beasts.
i have a 11 year old volvo xc60 (also inline 6, 3L turbo but only 4000 lb) and when the oil is fresh it really slows (engine brakes) when coasting. It's 2000 pounds lighter.
the trans takes a while to adapt just like any new car. Trans flush every 60k miles. Oil change every 5k miles.
Plus the 450 has the eq boost thing that takes energy from coasting to charge the battery.
GLE's weigh about 5,200#. You're looking at the GVWR, max loaded weight.
Old 05-27-2023, 12:23 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'09 C300 4matic,'15 GLA250,'07 Honda Odyssey, '18 GLE 43
Hi all.
Yesterday I was driving down the highway and noticed that when I release the gas pedal, the car quickly loses speed, even if it goes down a slight hill, it feels like the engine brakes.
Attaching a video, who owns a GLE v167 350 4matik, can you tell me if this is normal or not? And in what direction to dig?
Looks normal if you are on C or S mode. If you don't have the 450 you won't get the coast mode which puts the transmission to neutral then kills the engine and it just glides. The gliding feature is very effective and loses speed very slowly. When I use this feature in the highway I sometimes get +32mpg on the GLE 450.
Try this...next time you are in the freeway and there are no other cars behind you put the car to neutral and see if it will slow down the same way.
Old 05-27-2023, 03:37 AM
yabloky's Avatar
GLE 350
I put it in neutral yesterday, it slows down just like in eco mode and without it. No difference at all. Probably a small engine problem
Old 05-27-2023, 07:55 AM
  #32
mikapen's Avatar
It doesn't look like there's any problem at all. You've just proven it.
Old 05-27-2023, 11:58 AM
  #33
yeah I think it is normal then.
Old 05-27-2023, 12:17 PM
  #34
W205C43PFL's Avatar
I second that...
OP, nothing to worry about and the effect is also stronger with winter tires like you confirmed.
Quick Reply: The GLE loses speed quickly.
