Is this true for the Mercedes extended warranty?
1. Where is the full list of the uncovered areas by the Mercedes extended warranty?
2. Is pre-approval required before fix?
OTOH, an "exclusionary warranty" covers everything that's not expressly named as Excluded.
In most cases, an Exclusionary plan covers more than an Inclusionary plan.
Unfortunately the Mercedes is an Inclusionary plan, although coverage is more automatic.
Any questions about extended warranty coverage you can reach me at tgibson@highline-autos.com or (855) 924-1333
Mercedes-Benz Extended Limited Warranty:
Fidelity's small list of exclusions: BRAKE LININGS, BRAKE DRUMS AND ROTORS, DISC BRAKE PADS, STANDARD MANUAL TRANSMISSION CLUTCH FRICTION DISC, PRESSURE PLATE, PILOT BEARING, THROW-OUT BEARING AND ARM, AIR BAGS, SOLAR POWERED DEVICES, GLASS, LENSES, SEALED BEAMS, BODY PARTS AND/OR PANELS, WEATHER STRIPPING, TRIM, MOLDINGS, LOCK CYLINDERS, TIRES, WHEELS, ALL BATTERIES EXCEPT HYBRID/EV/HYDROGEN HIGH VOLTAGE BATTERIES AS LISTED UNDER GOLD, LIGHT BULBS, UPHOLSTERY, PAINT, BRIGHT METAL, FREEZE PLUGS, FILTERS, HEATER AND RADIATOR HOSES, EXHAUST SYSTEM, CATALYTIC CONVERTER, WORK SUCH AS FRONT-END ALIGNMENT OR WHEEL BALANCING (EXCEPT WHEN REQUIRED IN CONJUNCTION WITH A MECHANICAL BREAKDOWN), SAFETY RESTRAINT SYSTEMS, AUDIO/SECURITY OR OTHER SYSTEMS NOT FACTORY INSTALLED:
