Unexpected Acceleration
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Hate to say it, but this is an area well investigated by NHTSB. It's called sudden acceleration. All cars have it to some extent. Has to do with the amount of space bywn brake and gas pedal. People swear they are hitting the brake or the brakes won't stop the car. Finding is that people get confused and are stepping on the gas. All cars have brakes that will stop the car even with fully depressed accelerator. This is the reason for the brake interlock switch which started in the 80's after a series of accidents with audi. They also moved the pedals further apart. I had a chevy where it was easy to press both pedals at once, had to be sure to lift my foot and hit the brakes when that happened.
60 Minutes did a hit job on Audi back in the 80s where they rigged a car to experience runaway acceleration. The NHTSA determined that most cases of runaway acceleration are caused by miss application of the pedals.
I thought the hit piece Iwas rigged and some early Fake News, but I could see that pedal placement contributed to the reported events.
Toyota had a recall in the early 70s about feet getting tangled in the port-installed parcel trays, with the same unintended acceleration outcome.
I'm pretty sure that Audi changed the pedal position to help prevent this pedal mis-application. 60 Minutes did keep to their usual low journalistic standards and drilled a hole in the transmission and pumped in high pressure air to cause the runaway acceleration (don't ask me how this worked).
In the end it was proven to be pedal confusion.
https://www.curbsideclassic.com/blog...ation-debacle/
Did Mercedes ever investigate this situation? I just had the same thing happen in my 2024 300 glc. I was exiting a carwash just coasting when the car accelerated and the brakes did not respond at all. I had to run into a parked truck, flipped and totaled the car. Miraculously I was not injured baldy. Suffered a cut and a few bruises from the airbag, The truck then took out another car.
I have reported this to MB and they said they will investigate.
Very scary experience and I am suffering some form of PTSD when I get in a car now!
This happened on July 10, 2025yon
Anyone else experience similar situations?
- Vehicle speed
- Brake application
- Throttle (accelerator) position
- Steering input
- Seatbelt usage
- Airbag deployment
Years ago there were a cases
- Some involved sticking accelerator pedals (mechanical defect).
- Some involved floor mats trapping the accelerator.
but not found with modern vehicles. The common cause is driver pedal misapplication, not realized by the driver because of the shock of the unexpected movement.
While there is an Event Data Recorder (EDR) — often referred to as a “black box” — that can record limited vehicle and crash data, it is triggered by a crash. It records:
- Vehicle speed
- Brake application
- Steering input
- Seatbelt usage
- Airbag deployment
Please be sure to report this potential safety issue to the NHTSA here (takes about 5min or less to submit).
My car is a total loss; my passenger suffered injuries and was taken to the emergency room.
I have notified Mercedes Benz and NHTSA.
I had my GLE 350 suddenly accelerate long story short I side swiped a fence, ran over landscaping. The SUV would not stop my passenger suffered injuries and was taken to the hospital. Car came to a stop only when it hit a concrete pole. It is a total loss. It was a horrifying experience .
Any thoughts on the cause?
The vast majority of unexpected acceleration incidents were due to problems in the cabin, such as floor mats or operator error. The most common problem was pedal geometry. Very few were caused by equipment failure, such as certain cruise-control failures in the 1980s and early 1990s, where faulty vacuum servos or electrical shorts could hold the throttle open. There are no more recent examples.
My 2022 GLE 350 unexpectedly accelerates on its own. This happens at low speed right after braking and turning a corner, like pulling into a parking lot ..immediately after taking my foot off the brake after/during turning, suddenly the car takes off, like the distronic is kicking in, I have to quickly hit the brakes. It doesn't do it all the time but it's done it a dozen times since last September. I haven't taken it to the dealer yet as I thought maybe I was accidentally stepping on the accelerator after turning. I've been paying attention to when it's happening and it's definitely doing it on it's own. Anyone else have this issue?
thanks!
thanks!
My analysis is that it is the mild hybrid electrical motor that when you slow or turn, and you slightly press the accelerator, the electrical motor assist engages and tends to keep the velocity, or slightly continue to accelerate, but when you press the brakes, it immediately disengages the electrical motor assistance.
I don't feel it is a main engine acceleration..
That's my $0.02 cents..
