V167 genuine AMG brakes. Truly in the driver's seat.
Old Nov 15, 2023 | 05:36 AM
iCARMIX's Avatar
SPONSOR
W205 W213
Most of my MB customers have one thing in common: they're not afraid of being in control.
It may translate to many situations in life, whether a professional position, the role at home, in family, or even in the group of friends.
The desire for it is not enough though, sometimes it's about being capable, or by having the right tool for it.
The brake kit is the only safe antagonist of a car's speed, power and weight, it's what tames all those horses under your hood. It's what gives you, control.
The luxurious V167 is about 2.25 tons, and on that weight, rolling with a 1 POT caliper on the front may simply not be the preferred combination, in both performance and style.
Enter the genuine AMG brake kit, with a 6 Pot caliper on steroids, at the front, and 1 Pot for rear, combined with larger 400mm and 370mm discs respectively, high class, high performance.
Heat dissipation capacity at its finest, braking performance checked, you're in the driver seat, go go go!
Installation lasts about 3 hours.
Here is more info about this kit:
https://icarmix.com/product/genuine-...lass-x167-suv/
And here is the star of the day:
Old Jan 6, 2024 | 06:14 AM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
These look great, is there any option to run these calipers with one piece instead of two piece rotors in the front and back? Fitment would be on an 2019 E450, W213 class Thanks.
Old Jan 6, 2024 | 11:24 AM
mikapen's Avatar
No.
Either the caliper or the disc has to have a degree of freedom. A floating disc or floating caliper.
The big red brakes are fixed caliper, floating disc. The floating disc is also a thermal break from the hub assembly.
Old Jan 7, 2024 | 10:33 PM
iCARMIX's Avatar
SPONSOR
W205 W213
This disc is a genuine set up. and floating style has quite a few benefits, especially when it comes to heat management, warping resistance and even weight. I am curious though, why would you, as a driver, prefer one piece?
I'd love your take on this
Old Jan 9, 2024 | 02:10 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
Originally Posted by mikapen
No.
Not saying this is true for all vehicles and setups but I absolutely have a vehicle with a factory Brembo brakes using fixed four piston calipers and solid brake rotors. So long as the caliper is centered on the rotor the pistons will happily shift to compensate for small variances. The stock calipers float because the piston(s) are only on one side. With fixed caliper systems there are pistons on both sides of the caliper and thus the caliper does not need to float.
That said there are other advantages to the multi piece rotor.
I do find it odd that the OP claims the stock caliper is only one piston in the front. Standard brakes are two piston floating calipers in the front and one piston floating calipers in the rear.
Old Jan 21, 2024 | 10:03 PM
iCARMIX's Avatar
SPONSOR
W205 W213
Yes, that's right, my brain skipped a beat when I wrote it. Thanks for correcting me!
