2023 GLE450 Temperature guage in MBUX not accurate
Old Nov 30, 2023 | 01:45 PM
clivebaxter's Avatar
Mercedes GLE450
I have a 2023 GLE450 with 11000KM. So far no problems except this one. On the MBUX display (the right display panel) there's a menu option to show engine stats such as coolant and oil temperature, turbo boost, battery charge etc. all in one graphical combined screen. The coolant temperature always registers very low compared to the dedicated coolant gauge within the service menu on the instrument cluster (left panel). Even after many miles of driving it only reads 60 degrees or so. The dealer seems to have no idea but I thought I read somewhere (can't find it now!) that this was a known problem with the "Hermes"?? unit. Has anyone experienced this or have any idea of the cause and solution? Thanks!
Old Dec 1, 2023 | 09:36 AM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
Post a picture. That sounds like it's showing you transmission fluid temp and not engine coolant temp.
Old Dec 1, 2023 | 03:52 PM
jtjbt20x's Avatar
2021 GLE450W4 SUV
You are looking at the transmission oil temperature, not the water temperature.
Old Dec 1, 2023 | 03:55 PM
jtjbt20x's Avatar
2021 GLE450W4 SUV
And the HERMES module is for communications with the outside world.
Old Dec 1, 2023 | 04:59 PM
smholl's Avatar
2023 GLE 450
"You are looking at the transmission oil temperature, not the water temperature."
That is correct. Coolant gauge in center of driver display does not indicate a temperature value. Only cold/hot indication.
Old Dec 16, 2023 | 10:48 AM
Mercedes GLE450
Thank you all
Thanks you for pointing out my mistake. The MBUX display was transmission temperature not coolant temp. Thanks to all who pointed this out!
