I'm running 15mm hub centric on all 4 corners. Wheels sit nice and flush. Not sure about going bigger than 15mm.
awesome info, so we have the same car, I actually bought yesterday 18 back and 13 front, so similar, im glad you like the 15 all around, ill post pictures once installed,
Did you measure before you purchased?
I believe that on the coupe, the offset is different than on the SUV (which is what I have) as they appear to stick out more. May just be an optical thing........
Stock coupe:
Stock SUV:
Or maybe the rear of the coupe tapers in more therefore exposing more of the tire than the SUV......
I believe that on the coupe, the offset is different than on the SUV as they appear to stick out more. May just be an optical thing........
Yes I did measure, about 15mm front and about 20mm back so I went with 13 and 18
